Solid front axle conversoin?
Mont91
East Central Montana
Boy did I miss the boat on that one. I was refering to the front axles and didn't notice you said rear axle. Wish I had a sway bar like that on my 250 for camper hauling. Can't remember if they bolt into frame or have bracket on frame. Is it a single or dual axle?
metrojd
Pittsburgh,Pa
Sway Bar
Cory,
The bar comming off the rear end near the spring perch is the tracking bar the other end has a bracket with 3 holes in it.
That bolts th the crossmember.
That keeps the rear end from dancing from side to side.
John[/QUOT
O.k. the thing that i am calling the torsion bar goes from side to side of the rear end and attaches to the frame via threaded rods w/ bushings on the other.
thks cory
That is the sway bar.
I would say that is an option.
Keep it or loose it.
Thanks
John
truckonfire
