DavidS
Oh also, Happy Thanksgiving everybody!
If it looks like this, yes. They are awesome.
Do not get the Mitsubishi one that looks like this:
I've had two of those and they are also gear reduction [somehow], but they've both died quickly and gradually day by day cranking slower until one day they just crapped out.
Most of my hatred for the Mitsubishi style is personal preference and not a summary opinion of the site but I will never put one of those on anything again. Even brand new they couldn't spin the engine at all like the nippendenso style does and they are easier to install.
Take Glow plugs out and crank it over with a torque wrench. It should spin pretty easily; and if it does, Replace starter if not pull motor?
Cranks fried?He already pulled the glowplugs and tried to bar the engine over manually and it still is locked up, so that rules out hydrolockKinda sounds like hydrolock. When the starter did work, it was slow, and no amount of battery/cable/ground fussing has helped.
If your engine has block worm (cavitation), it will do as you have described when trying to crank. If the affected cylinder is left in such a state that the hole is exposed, it will fill the cylinder with coolant and lock the engine.
It still may be a ground or starter problem, but you have already done enough there to feel some sort of difference. If you pull the GPs and can turn it at all, watch for coolant to come out of one or more cylinders. OR- a spun main bearing will do a similar thing. But these engines are known for block worm, not spun main bearings.
