arnolt
I have a 1993 F350 7.3 diesel, with an ATS turbo system. The truck threw the serpentine belt the other day and I can not quite figure out how the tensioner works. I went to NAPA but none of their tensioners match what is on my truck. Mine looks like it is bolted to the block with a torquex or allen head bolt and there is an ear with a small little shock absorber attached to it and to the trucks vacuum pump. Do I disconnect the shock from the vacuum pump then undo the bolt to remove the tensioner? Do I also need to remove the idler pulley to get the assembly out? Does the little shock absorber provide the necessary belt tension, or is there a spring in the tensioner some place? There is no spring visible anywhere. There is a number on the front of the tensioner F4TA-6B209EA. If I can figure out how the tensioner works I can try to reattach the belt and see if the tensioner will maintain the proper serpetine tension. Any help at all with a source for the tensioner assembly or procedures for it's removal and replacement would be greatly appreciated.
Charles
Charles
