My oil results have been coming back showing hig iron wear. Now I'm showing high iron and chrome.. The chrome is the rings. Blackstone is suggesting high meteal wear somewhere... Maybe a broken ring... I'm a little suspect... Heath got a report that was bad too. Now I wonder if this is a play to get more "business" seeing they suggested a 2000 mile sample time. I probably will do that but.... I wont change the oil and I will be sending another sample to a differant lab for comparisons. I think Cat does testing and there is one near me..... All I have done is change injectors by removing the injection pump. I know that bolt loosening and tightening scuffs off plenty of metal but now the report is telling me there is so much soot they can't give me a viscosity reading... ***.... I have better injectors in the motor now.... I have been turning down the pump... The smoke out the tail pipe has been reduced to almost nothing... I have no blowby at all. I can run the motor and nothing comes out the oil fill spout and I'm not burning any oil... I will be doing a compression test later on. My last test was 530 +or- 5 lbs.... At least I have a base line to go from.... Mybe its time to start building another motor.....
