PwrSmoke
I read somewhere that a fresh idi should push anywhere from 450-500 psi and do any other years have a minimum pressure that I can compare too? Thanks
Well, I think that 450-500 psi was in error.
I have manuals from '84-94 (6.9-7.3 IDI + 7.3 IDIT) and they all say the same thing as I posted above.
The GM 6.2L diesel (also an IDI with a similar Ricardo-type combustion chamber) manuals do list a compression pressure and since they had a nearly identical compression ratio (21.5:1 and the cam profiles are similar), it might be relevant. The GM manuals lists 380-400 psi on a warmed up engine. That's right about where you are, though if the engine wasn't warmed up when you tested, it will read lower. Again, I think you have nothing to worry about.
