Saginaw Power Steering Pump
88IDITurbo
88IDITurbo
Portland, OR
Has anyone swapped in a Saginaw power steering pump into their rig? If so is there already a thread that exist because I could not find anything using the search feature.
If someone has done this, what all is involved and do you have pics?
rjjp
Needs to go test
Clare, Mi
I haven't done it, just read threads on it.
But, two common ways;
1. Find an IDI van in the bone yard and pull the accessory mounts off it.
2. Find the rare Ford bolt pattern Saginaw pump.
subway
be nice to the admin :D
York PA
oldblue05 made his own bracket for a saginaw pump. i had one and took it apart now i cant find the damn pieces.......
There are lots of threads here on this...and here is one...but for gassers...this is the alleged and much coveted adapted pump to fit our PS pump housing with Serp belts as far as I know...it may fit non serp brackets I don't know...
If you find a diesel van it's got the brackets...
Looksee here
http://www.fullsizebronco.com/forum/showthread.php?t=65983
Looksee here
Vincent
