Put the biggest tranny cooler you can find on there, swap it to synthetic fluid. Check your timing and make sure it's advanced as far as you can stand it. set it at min 9.7 deg btdc by the pulse method, if you are going to be up in the mountains at altitude above 3500 ft on a regular basis, you may want to shoot for around 10-10.2 deg and cut your fuel screw BACK to where you dont have any black smoke unless at full throttle and then only briefly. Running n/a having excess fuel at altitude will only raiseyour egts, and bog you down, it will not get you over the mountain, leaning out and bringing the timing up will give the power needed to pull. Keep teh RPMs up above 2500 while climbing
My trailer is heavier than yours and so is my truck , the combination is around 18k and it pulled fine before I put teh turbo on . It would run with the big trucks out on the highway. climbing hills I would be passed by some and would pass some others. Can't ask for much more than that. I wasn't setting any speed records, but it was pulling just fine. The addition of teh turbo was icing on the cake
