h2odrx
Anti-O
which would you use for summer driving? and why? what are the bennys?
15W40
15 Weight cold
40 Weight hot
Easier starting cold, higher oil pressure hot. The IDI's aren't known for high oil pressure anyway, so I like to do what I can to raise it.
I see 60 psi at highway speeds
15w40 is all I've been using and now i've added it to my 3.2 that has 180k miles. So with My 87 I see 20psi at idle hot and 60psi at 2200rpms.So do I. Is that with 15w40 or 30 weight? My small blocks generally see 80 or so at the same speed...and maintain 40+ at hot idle - not something most IDI's do.
