Pulled all my injectors today, most were leaking... rear 2 cylinders had what appears to be oil on the tips.
Any idea? Rings, valve seals, head gasket? CDR valve was cleaned out about 100 miles ago, appears to function right.
I'd certainly be surprised if a ring is bad with only 136k. Can a stuck ring do this?
If I were a betting man, I'd say a bad head gasket, the cdr valve may have let oil into the intake. The extra BTU's lifting the heads in back.
Only other thing I can think of, is the PB blaster actually seeped all the way down and pulled crud with it...
