Va_Mike
So a quick update.
I got back to work on the truck this past weekend. I replaced the fuel filters and filled with fresh diesel (5 gallons mixed with 1/4 of a qt of diesel clean and a little 2 cycle oil) I installed clear tubing on the return line from the top of the injector pump and the line that returns to the filter housing. I am also running off the fresh can of fuel and have by passed the fuel tank just to rule out bad fuel.
I loosened the injector lines to all 8 injectors and cranked the truck for a few sets and was able to get diesel to all the injectors. after that I tried a little starting fluid and aside from some clattering it didn't do much (very little whiteish smoke out of the exhaust)
I tried again with some brake cleaner and she tried to start but nothing more. I am wondering if I am getting fuel through the injectors. I am hoping that letting the cleaner sit in the system may loosen things up a bit.
I also am wondering if I should try and advance the injection pump? in the picture a few posts up you can see the timing marks and the pump is currently sitting at about a dimes width advanced. I don't know how many mile are on the pump, only that it was a good condition pump off a running truck that was swapped on to this truck. if I advance it more would it perhaps build more pressure to fire the injectors if that is what is wrong?
