Hilly
I had the very same problem. Gave the FSV the deep 6, and use the front tank as a
transfer tank with a small fuel pump. Used a right angle thread/barb brass fitting, drill
a hole in the side of the rear Fill Tube, just so the threads catch. Then JB weld it into
place.
I have a 38 gal rear tank, get down to 500 miles then transfer the fuel, takes 40 - 45 min to
transfer. Use a small Cube Faset Pump.
The front tank when completely empty, will hold 21.7 gallons when the handle clicks off.
If you are interested in the 38 Gal tank. It is a F26E. Think it is 7" deeper.
But you may not be able to install the Spare under the bed.
Depending on mileage, I "can" get 600 miles out of that tank.
OG-thanks for that. The 38 gallon tank/sump/FASS/etc. is all happening. Need to get the bed off soon and take a look at the front tank to get an idea of what is needed for bracketing to fit a 60ish gallon aftermarket SD tank in there. 100 gallons or so is enough onboard to keep me from having to put a transfer tank in the bed.
The fuel pedestal in the engine bay needs to go away ASAP, so looking to get the parts all stacked up and just replace it all along with the entire fuel injection system. It's all so old and ugly, going to bite the bullet and just do it.
