DrCharles
Tighten it 'til it strips, then back off 1/4 turn?
I suspect you are right about the cause since you carefully cleaned out the holes. If your studs have hex broaches, an Allen wrench will keep them from accidentally rotating. If not, maybe install them with Loctite after backing off from hand-tight as you describe...
