Regular Cab Interior and Extended Cab Interior
jhenegh
Truck Still Earns its Keep
Deerfield, WI
So I want to get rid of my captains chairs and useless tiny center console in my extended cab and just put in a bench from a regular cab. More room to throw crap that way LOL Do they fit with little to no modification? Hole all the same? I've found a '94 reg. cab with a decent interior that I'm considering buying and raiding for this purpose.
Conversely, would my bucket seats and console bolt into that regular cab easily for potential resale? :sly
If memory serves, the holes in the ext cab do not line up with the reg cab as far as buckets go. I don't believe it is simply a bolt in affair for the bench into your truck. I believe that there is a seat frame adapter that you can buy for the reg cab to make bolt in of the buckets easier. The extended cab is the ******* child. It's like the broncos more than anything else it seems.
I'm sure someone else will chime in with confirmation or correction of the info I gave you.
jhenegh
Deerfield, WI
Alrighty. Would Buckets out of a Bronco bolt right in then? Found some good lookin' aftermarket red ones available from a 90-96 Bronco (who ever thought red was a good interior color?)
Double-S-Diesel
parts seller
derry pa
the bench will bolt in using the outer holes, but the buckets will not fit the reg cab without drilling the inner holes
Here is what I found...
Some holes lined up just fine, one or two didn't, however....
I looked under the floor pan and wow..the welded on nuts are there in the right place..hmm..OK
Drilled out the center of the nuts and then lo and behold I had holes that lined up!
This is just my personal experience with this same situation. A family man needed just ONE more seat so I gave him my split bench for his truck, kept his worn out buckets!
JM2CW
Al
cheepsk8
North East wyoming
the bench seats that I have seen in the bronco and extended cabs sorta hinged in the middle to allow better access to the rear.
wallbrad
i be a injuneer....
S.E. Connecticut
From your signature, I'm presuming that your truck is the '94, not the sold '91 you had, but you might still want to check for cracks in your floor pan when you take out the captain's chairs. There was a Ford TSB for the pre-90 models about how the seat mounting on the captain's chairs led to cracking in the weak floor pan design. I have an '89 crew cab with captain's chair, and I just replaced my carpet on Sunday. When I pulled the carpet, I noticed a really bad cruciform-shaped crack (about 3 inches x 2 inches, complete with daylight coming through!!) right where the transmission hump met the rise for the driver's seat. I ended up doing some extensive weld repairing to a very large section of it to make sure the situation didn't repeat. (I also laid down weld bead going about an inch past where the crack stopped in each direction of the 4-way crack ground the whole thing smooth to mitigate any potential crack propagation.) I think one of the POs was a really fat *******, because he also trashed the driver's seat track! (Had to replace that too.......)
If anyone else who might follow this thread is interested, here's the ford TSB:
-Brad
[[[ EDIT: IGNORE THE PICTURES IN THIS POSTING AND SEE THE ONES ATTACHED TODAY (12/29/13). There must have been embedded links that keep changing the graphics....]]]
SHEET METAL - FLOOR PAN - CRACKS NEAR CAPTAIN CHAIR SEAT TRACK ATTACHMENTS - VEHICLES BUILT BEFORE 10/16/89
Article No. 90-6-12
LIGHT TRUCK:1989-90 BRONCO, F-150, F-250, F-350
ISSUE:Floor pans may crack near the seat track attachments on Bronco and F-Series Super Cab trucks equipped with captain chairs.
ACTION:Install floor pan reinforcements on the top side of the floor pan. Refer to the following procedure for service details.
1.Remove both front seats and seat tracks. Refer to the 1989/90 F-Series/Bronco Shop Manual, Section 41-01 for service details.
2.Inspect the seat tracks for cracks. Replace any damaged tracks. Refer to the 1989/90 F-Series/Bronco Shop Manual, Section 41-01 for removal and installation information.
3.Remove the carpets/mats. Refer to the 1989/90 F-Series/Bronco Shop Manual for service details.
4.Inspect all eight (8) seat track attachment nuts on the floor pan. Fusion weld any loose nuts to the floor pan.
5.Remove all sound insulation material from the floor pan in an area big enough so that the reinforcement does not contact any insulation.
6.Clean the floor pan surface with 3M General Purpose Adhesive Cleaner.
7.Inspect the top side of the floor pan for cracks.
8.Apply 3M joint and seam sealer on the top of each crack.
9.Remove the floor pan reinforcements from the service kit. Place them upside down on a work bench or table.
10.Clean the bottom surface of both reinforcements with 3M General Purpose Adhesive Cleaner.
NOTE:A 3M AUTOMIX APPLICATOR GUN CAN BE PURCHASED FROM YOUR LOCAL 3M SUPPLIER. THE APPLICATOR GUN IS REQUIRED TO APPLY THE 3M STRUCTUAL ADHESIVE.
Figure 1
Figure 2
11.Apply 1/4"-3/8" (6.35-9.53 mm) beads of 3M Structural Adhesive to the bottom surface of both reinforcements as shown in Figure 1.
NOTE:ADHESIVE HARDENS WITHIN 30 MINUTES. PERFORM STEPS 10 THROUGH 13 AS SOON AS POSSIBLE BEFORE ADHESIVE CURES.
12.Place the left hand reinforcement on top of the floor pan sheet metal on the driver's side, Figure 1.
13.Secure the reinforcement to the floor pan with the (4) seat track mounting bolts and (4) flat washers, Figure 2.
14.Place the right hand reinforcement on top of the floor pan sheet metal on the passenger's side, Figure 1.
15.Secure the reinforcement to the floor pan with the (4) seat track mounting bolts and (4) flat washers, Figure 2.
Figure 3
16.Using the holes in the left hand reinforcement as a guide, drill six (6) 1/4" (6.35 mm) diameter holes through the reinforcement and floor pan in the locations shown in Figure 3.
a.Install one (1) pop rivet in each of the critical locator holes as shown in Figure 3 immediately after drilling the individual hole.
b.Drill the remaining twenty-seven (27) 1/4" diameter holes in the reinforcement and floor pan.
c.Install the remaining twenty-seven (27) pop rivets.
d.Remove the (4) seat track mounting bolts and flat washers.
17.Repeat the above procedure for the right hand reinforcement, if required.
18.Spray Super Seal on top of both reinforcements and about 1" (25.4 mm) beyond the edge of the reinforcements.
19.Replace the carpets/mats.
20.Replace both seats.
21.Raise the vehicle and spray Super Seal over the bottom side of the floor pan to cover all cracks and pop rivets. PART NUMBER PART NAME CLASS
FOTZ-1811298-B Floor Reinforcement - RH. CG
FOTZ-1811299-A Floor Reinforcement - LH. CG
382601-S100 Pop Rivet - Pkg. of 10 S
E9TZ-9860094-A Seat Track - LH C
E9TZ-1862506-A Seat Track - RH C
D8AZ-19515-BA Super Seal Compound B
OTHER APPLICABLE ARTICLES:None
WARRANTY STATUS: Eligible Under Basic Warranty Coverage
OPERATION DESCRIPTION TIME
900612AT Install Both Reinforcements 3.3 Hrs.
900612A Install One Reinforcement 2.5 Hrs.
900612BT Install Both Seat Tracks 0.3 Hr.
900612B Install One Seat Track 0.1 Hr.DEALER CODING BASIC PART NO. CONDITION CODE
7011215 63
OASIS CODES: 1051, 1200
wallbrad
i be a injuneer....
S.E. Connecticut
I realized that the floor pan thing I spoke about above was also the subject of a warranty recall (not just a TSB) for 1989/90-Model Bronco and F-Series Super Cab Trucks Equipped With the Captain Chair Option. Go to your Ford Dealer (if you affected) and refer to "OWNER NOTIFICATION PROGRAM B93".
Also, the pics I posted above must have had embedded links to the all data file I copied it from, because they went bye-bye and seem to keep being replaced with random pictures. Ignore the ones above. Here's the replacement figures,FYI.
-Brad
kbeck
