Natehimself36
I blew up my IDI so I’m trying to get a plan going. I’m not in any hurry to get this thing going. First i was thinking of rebuilding it. Getting some nice parts, turbo, studs and all that good stuff. I thought the Cummins swap would be out of the question because of price and difficulty and all that. After some research i see that its arguably easier to do than a PS swap and i could probably do it for the same price give or take a few hundred. I’m going back and forth between all these options. Ive moving farther and farther away from the PS swap purely because of how much of a PITA it is without a donor. I plan on buying bits and pieces throughout the summer and doing it this fall or winter when work slows down.
Another thing to consider is that the truck needs a new transmission. Currently it has the E40D and its on its last leg. I thought for sure it would fail before the motor but i was wrong. I am going to put a zf5 in the truck unless someone has a better idea. The truck is a 1993 f-250 4x4 IDI with the ATS spinny thing, E40D. I’m dont like the auto, never have liked automatics so i really want to avoid it if i can. This isn’t a little project, that’s why I’m not in a hurry and also why I’m open to a lot of options. If i blew a head gasket i would just fix that and keep going, sadly this isn’t the case. One of my connecting rods became a disconnecting rod and went ahead and made a hole in the block. Who knows what else is damaged.
I’m going to make a thread following the progress of the project once i get a plan going and get some progress made. Any ideas are greatly appreciated. I would like to hear everyone’s thoughts. Ive also thrown around the idea of a DT360.. i like that and the 466. I wont do the latter but the 360 is something to be considered. I’m more prone to do one of the first three ideas though. Thanks guys, i appreciate it. I am set on fixing this **** and not replacing it or scrapping it. This swap or rebuild WILL happen so don’t consider this another thread that some kid writes up and doesn’t follow through with.
Thanks, Nate Himself
Ps, I tow a lot and drive a lot. On average 100 + per day. Tow heavy 1 ton plus.
