rearend width on cab/chassis/flatbed vs. dually truck
jibronee
Slo, California
Do the cab/chassis early 2000's, F450's/550's have a narrower rearend than the regular dually trucks of same years? I'm aware that the F350's cab/chassis have narrower rear axles. Working on a project and I'd like to use an F450/550 rear axle the same width as my cab/chassis F350 axle.
Thanks
u2slow
bilge rat
Coastal BC
Should be the same or similar.
The C&C diffs are narrower than dually pickups, but the width isn't exactly standard. The wider format may still be an option, so watch for that.
Gary B
Clear Fork, WV
the industry has gone to a standard 34" frame for cab & chassis, and it may be metric measure in today's truck but will be very close
u2slow
bilge rat
Coastal BC
The frame width is more standardized than the axle track width. However, Dodge c&c's kept with a 38" frame at least into the 6.7L era.
