Rear wheel lock nut torque
RLDSL
Diesel fuel abuser
Arkansas
You will need to specify what rear axle you have or it's anybodies guess
RLDSL
Diesel fuel abuser
Arkansas
Well, you ve got a couple of things in your sig there, so I didn't want to asume. Yes, 55-65 ft lbs then back off 5 clicks and you're good to go
Optikalillushun
Coal Region, Pa
I torque it to 65 and set it back 8 clicks. Seems to rotate smoothly, with a slight resistance but i did put a little dab of wheel bearing grease to prevent a dry initial start and it was like peanut butter cuz its so cold.
