Chuckdiesel
Ok so the passenger side rear hub is jacked up it cant be turned by hand and it locked up on the interstate today and has only moved a little bit with 4 low in 4 wheel dr. I am trying to take it apart to get to the bearings but I cant. I have the axle out but the outer bearing nut will not budge and I mean it. I broke a rachet and bent the tabs on the hub tool a bit! I dont know what to do because its really stuck.
I had that happen once and it was not pretty. You nay need to get someone that is really good with a torch. I torched mine apart but it took time and patience. Definatly not the job to do with a beer. since its already kinda trashed you could try heating it up a little. Just try not to heat the spindle too much if using an oxy/acetylene torch.
