Goofy- i am running stock tires. i will try to post pics in an album in the next day or two when im off work. im guessing for the worst on everything, this guy was around 80 i bought it from and had it since new. so being said, he took care of the truck but always expect the worse. i want to drain the rear end, coolant, brakes, etc. anything i can do to make it a happy girl. when i do end up servicing it i will have to look on here and get an idea how to do it. never have taken a rear end apart except for new oil. never serviced one.
Stock tires, 4.10's and a ZF overdrive 5 speed...my truck would top out at about 85 MPH. With stock tires and 3.55's and a ZF...I don't knwo what she will do....never tried.
I am going to say that your truck HAS 4.10's. 235/85R16 tires, at 32" tall, with a 1:1 high gear ratio (-12 ot so % for slip in the TC) and 4.10's puts you at about 72 - 75 MPH at 3200 RPM.
Now, if you want to jack up one wheel in the rear, and try and turn it...this will tell you if it is limited slip. If the wheel spins freely with the transmission in neutral, it's an open carrier. If it only turns a little bit, then binds up...you have a limited slip...or a broken open carrier.
Go to your driver's door, and look on the jam towaeds the back of the cab. There will be a sticker with your VIN on it.
Look closely, it will have an "AXLE CODE" Get either two numbers, or a letter and a number from it. We can try and tell what that truck has in it now, or at least what it left the factory with.
