rear end identification
yotekiller
Va.
figured out i have a 4:10 rear, axle code was 65, so no limited slip.
is there a way to tell if its a sterling 10.25 or dana 80.
it is a 96 DRW F350 and what the fluid capacity is?
Thanks
u2slow
bilge rat
PNW
It's the 10.25.
The Dana 80 is 10-lug and would be an f-superduty truck.
Buy a 5gal bucket of gear lube and a bucket pump. You'll thank me later.
yotekiller
Va.
It's the 10.25.
I see 75/140 is recommended, dang i have plenty of 80/90 and a way to get it in the fill no problem.
u2slow
bilge rat
PNW
I've used 80w90 in all my 1ton diffs for 25 years.... Ford, Chevy, Dana.
Ferdy Mint
Central Texas
I run 80w90 too. I have a D80 in my SD350, a D135 in my SD550, and Sterlings in all the SRW trucks. The 135 gulps down 3 gallons to change. I buy 5 gal pails at Tractor Supply, and a pump from NAPA. Oil's going up, so stock up now.
captain720
Washington
I’ve used 80-90 in all my rear ends I assumed these were the same……. I know I have 80-90 in my 87 and that’s what the parts book said to use.
yotekiller
Va.
I have been stocking up.. reason i have so much 80/90 and got shell Rotella all over the place including 5gal buckets lol..
IDIBronco86
