badasp118
I was told by the operator of a local salvage yard that 3:55 gears will not fit in my rear end in place of my 4:10 gears? I know alot of you have done this swap.........any input?
Whynot? lol. It is just a ring and pinion swap. Tell him to point out your spark plug wires so you can change them too lol
3.55's are the option for Ford rearends, and 3.54's are the option for the Dana rearend.
He may be technically correct that you cannot swap "just" the ring and pinion. I have run into this before. The thickness of the ring gear varies by ratio, so some gear ratios require a carrier with a different offset.
No big deal, but you may want to swap the pinion and carrier/ring gear assembly.
If it was me I would rather just swap the whole rear axle if it is available.
Probably true- It been a while...I ran into the issue while putting 5.38's in my Bronco!
5.38's? Dare I ask what size tires were on this thing?!
Yea.Slide out the axles,drop the "punkin". In with the new and that's it
