Radiator Options
bike-maker
albany, OR
So my radiator has decided it's not much longer for this world and has sprung a leak. I will soon be looking for a suitable replacement.
Are there only 2 radiator sizes that came in front of the IDI's? And since I'll be looking for a new one, is there a particular size that works better than the other(s)?
LCAM-01XA
my very own hell
To my knowledge yes, only two sizes - one is low and wide (37" IIRC), the other one is taller and narrower (31" or so). Measure up what you have now and buy that, cause of you go for the other style you'll need different brackets and such...
No brackets will change the wide for the small radiator. You will need a complete radiator support up front... Thats just way too much trouble.... Count how many fins per inch you have now. Make sure the replacement radiator has at least that many fins per inch too. Also don'y buy the dimple three row. They just wont keep these motors cool. Get a 4 row with 16 fins per inch. The 12 fins per inch will not cool as well either no matter how many rows it has...
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
I have a 3 row aluminum radiator that has 1.25" tubes........ Works great and the truck never comes off the " C " on the guage even when towing. ;Sweet
LCAM-01XA
my very own hell
Gary, I thought the rad supports were different, but wasn't sure on it - thanks for confirming.
Diesel Max, where in "NORMAL" do you find a "C"? ;)
Brianedwardss
Oregon City, OR
The last IDI I owned would barely go past the C even on the hottest days, but more than likely it was the sensor not telling the truth. If I had a custom radiator I may have believed it.
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
Probably the far left. (stands for cold_
Correct...................... Gauge reads from left to right, C --- Normal --- H Gauge runs between the C and normal. Glad I could provide some amusemnt for everyone.....:D
LCAM-01XA
my very own hell
And we appreciate it :D Have you verified the actual coolant temperature somehow, for instance with an IR gun pointed at the upper rad hose?
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
No........... But since you mentioned it and I have an IR gun I will check it tomorrow.............. :D
That upper hose temp may surprise you too... Do the top and bottom hoses just so you know the differance in temps.
idipwr
Ohio
Where is the best place to get a 16fin per inch 4 core radiator? Aluminum or Oem style?
