Pump turn up!
Jhall
Florida
Any precautions for turning up the pump a couple flats on a 7.3 factory turbo??
Thewespaul
Bulverde, Texas
Do you have gauges? Is everything stock on the truck or have you done other upgrades?
Jhall
Florida
No gauges , all stock. I’m in FL so no hills and I only pull a bass boat once in a while
Macrobb
North Idaho
It's a Good Idea to install an EGT gauge when messing with more than stock fuel.
Once you do that, though... the turbo can handle more than your pump can put out, period... above about 2200 RPM. This meams you can get a hefty chunk of power(easily 50% more than stock) out by turning up the fuel screw.
You will not want to floor it off idle, just ease into it and then floor it once your revs are above 2K...
Thewespaul
Bulverde, Texas
Right answer is get gauges then turn fuel up... but you can get away with a flat or two without an egt gauge
With no turbo my suggestion is install an exhaust gauge called pyrometer. Otherwise you have no idea what the exhaust temp is now. Say your now borderline running too hot.Turn it up 2 flats and you face horrible piston melt down. Its your call if you try to get away with turning it up with no instrumentation telling you any good information.This forum has seen the non turbo engines run hotter exhaust temps than the turbo engines. Remember a turbo is forcing more air into the cylinders and this has a cooling effect.thats why we can turn up the fuel with a turbo. More forced air means more ability to burn more fuel..Equals more hp and torque...
Macrobb
North Idaho
He *has* a turbo. Factory turbo.
Lance
