TestDriver
ok well all our pumps confuse us at times but something were familiar with can be used to explain them thats youre brake system. think of the pump as the master cylinder and the injectors as the wheel cylinders.
the pump with a bigger piston creates a force on the fluid which is transfered to the injectors with a theoretical smaller piston creating more pressure.
Interesting stuff here. I've got such a hookup to the advance/high idle circuit for my old, tired pump. On hot days, it's the only way it will stay idling with hot oil going through it. I use it at stop lights mostly.
As for the quote, you have this reversed. In a fluid system, for any given pressure, a larger piston will exert lower force than a smaller piston. If you consider that pressure is a unit of force over area, P=F/A, when the area increases, the pressure goes down. Likewise, if the area decreases, the pressure goes up. That's why we can jack up things with bottle jacks with pistons of about 3/8" diameter.
What you said about the DB4s is interesting. Do you know what the diameter of those plungers is?
