psd turbo has arrived
punkmechanic
diesel tech
North East Portland Or
good luck. I got another one yesterday and a line on a couple more. let me know how it works for you. Im gonna start on the 6.9 in the garage soon for my fiances scout. no psd turbo on that, but it wont be stock either.....
you all know what I "come across". thats all Im saying
dyoung14
Is getting worn out
spencer,tn
well i done some looking around and test fitting yesterday, the exaust side is about the right size to fit, the damn intake side is huge, im going to have to do something to my fire wall to fit the thing were i want it or else mount it down under the truck.
flatlander
plays dirty when losing
ft. wayne IN
If you put it under the truck you'll have to turn the compressor side 180. If you look at the pics of mine you'll see that it works perfectly on the pass. side frame rail. Problem is in that config. the oil ports are facing up instead of down. To turn it over you'll have to unbolt the compressor side and redrill 2 of the 4 bolts because they aren't a square pattern. More like a trapezoid.
dyoung14
Is getting worn out
spencer,tn
yours is a non gated psd turbo right? whats the difference between the gated and non gated turbos, besides the 1.15 a/r non gated, 1.00 a/r gated?
dyoung14
Is getting worn out
spencer,tn
o i thought yours was a non wastegated, mine is also a wastegated psd turbo, well im going to se if i can modify the firewall a little bit and fit it up to, if not, its going under the truck.
