Diesel Max
93 F-250 4X4 - 7.3
What is the purpose of propane injection on a 7.3 and what beneifts do you get from having it ?
When you run propane through your engine it burns more of the fuel in the chamber. Normally you only burn 75% or less of the fuel that is injected in the chamber but the propane acts as a catalyst and burns almost all the fuel. In return you get better mileage and more power.
Ive heard several different things about mpg gains but i think its from 3-7 mpg depending on how you drive and other things. You can gain 100 hp. When you use propane a tank that fits on a bbq grill i forget what size 20 or 40 # will go roughly 400-500 miles. its not a complicated thing to do but if you do it wrong you are sitting on a BOMB so be carefull make sure nothing is leaking.
