ericwade381
does anyone know where I could buy a pre Bledmaster cylinder? Thank you
Absolutely yes. Even with the master cylinder bled before install, some air's going to be introduced into the system when you swap the lines over. More to the point, the brake fluid on any vehicle should be thoroughly flushed every two years or so.I'm assuming it's best to bleed all my breaks after that's done?
How would they ship it? It only takes 30 seconds to bench bleed one.
