PowerStroke lifters
Slicknik
Burbank, CA
Does anyone run anything else besides stock lifters on your idit?
Found some power stroke lifters with guides for my application or just get some motor craft turbo lifters for my setup .
I broke a lifter and I’m tearing the motor down to the intake manifold to get to them. I believe they are stock off my 91.
Also if someone could tag a link for the IP removal and install I would appreciate it, going to you that search button for that one
frankenwrench
overkill is under rated!
Weatherford tx
I am running 6.0 powerstroke lifters as we speak in my n a 7.3. They are all the same in 6.9 all the way to 6.0. I have been told the same part number also is for the 6.4 but I am unsure it is a fact. But I do know that the 6.9 7.3 n a 7.3 idit 7.3 ps and 6.0 ps all use the same lifters
Not to mention the GM 6.2/6.5 engines use them (I'm not sure about the 5.7/4.3 diesels). There's also a big block Olds that uses the same lifters.
Lumberjackchuck
New Jersey
Not sure how people feel about them, but I ordered a set of Johnson Hylift (US made) lifters here for my rebuild. Just the normal set, not the expensive slow leak down ones
chillman88
Central NY
I'm pretty curious. I've been considering replacing mine with my new cam and they're a bargain for the price being USA made if they're actually good quality. Let us know what you think of them compared to the stock ones when you get them please.
To confirm what others said, here is another thread on the subject.
Rocker Arm removal instillation
https://www.oilburners.net/threads/7-3-idi-rocker-arms-removal-and-instillation.75119/
Injection Pump R&R plus other info.
Lumberjackchuck
New Jersey
Yeah I’ll definitely report back when I get them. I’m actually getting my block and heads back from the machine shop on Monday so I was prob gonna do a build thread on my truck.
But I think they’re worth it if they’re quality and US made like they advertise. Otherwise I was going to disassemble and thoroughly clean all the original lifters which would take a lot of time. Time is something I don’t have much of, especially this time of year I’m working every day. So I’ll be burning the midnight oil to put this motor back together
Gerhard
