I had to take the rockers arm out drivers side to clean them from major rust that i discovered covering the rockers arm , Any special way to install them back in place after i clean them . Accidentally the rockers got mixed together , I hope that doesn't matter
What's the Torque for the rocker bolt Is it 20ft or 24 ?
rerouted my turbo drain line from the VP to VC , What is the best way to plug the big O hole where the drain tube use to connect to ..
