rhkcommander
I found a ZF 5 4X4 not sure if its a 420 or 470 for about 750$ guaranteed to work but is used. Diesels are rare in the junkyards around here, let alone a 5-speed Ford. T19 still works but is rough and since it looks like I will be rebuilding the spare 6.9 soon, why not upgrade to an OD trans
For the swap, is it just a bolt in replacement of the T19 or will I need some parts? IE driveshaft, transfer case and driveshaft, shifter, shifter floor pan?
I've read that the trans crossmember needs to be moved back too. From what I've read I should be able to bolt it in minus the crossmember needing relocation.
Thanks
Thanks
