Positive Battery Cable
79GLIDE
Omaha
Any recommedations on a supplier of a quality positive battery cable. Checked out White River Diesel, but I wanted other opinions before dropping nearly $100. Thanks in advance.
sassyrel
iowa
yah,,head for your favorite local semi tractor place..unless the ends of the cables are totally rotted,,they can crimp new ends on,,right on the vehicle!! cost much less than 100,,and the ends they use,,are zinc coated copper!! i use the same ends....
Matrix37495
The Amish Wolfman
Terre Haute, IN
I had mine built at NAPA. 2/0 between batteries and 3/0 to the starter for about $95....
Make sure they do a good job sealing the ends though.... they didnt on mine and i had to fix one of the ends.....
f-two-fiddy
Duluth, Mn.
I found a brand new one at our local salvage yard. Musta been trying to get over a hard start problem before they got frustrated and junked it.
mobilemech
Redding CA.
check with the Interstate battery dealer in your area, they have the possitive cable for around 75.00 and it is 2/0 size, OEM quality.
MIDNIGHT RIDER
That silly mid-cable positive terminal was Ford's way of saving a few dollars per truck; it definitely IS NOT good practice and SHOULD NOT be replaced with the same style.
It is far better to make TWO separate cables, one from battery to battery, and a bigger one from the second battery to the starter.
This is simple with threaded-stud batteries.
With lead-post batteries, make the cables the same as for the threaded-stud batteries and use either marine-style terminals or military terminals, either of which include a threaded bolt for copper-lug attachment.
Thus, when it is time for new batteries, the copper-lug terminals/cables are already right there.
No way would I throw good money after another of those mid-terminal cables. :)
mobilemech
Redding CA.
It is far better to either make TWO separate cables, one from battery to battery, and a bigger one from the second battery to the starter.
Agreed, there are better ways to make the pos. cable. The way I took the original post, he was looking for a OEM style cable, just providing another source. The military style terminals and lugged cables are a far better way to set up the pos. cable.
cbarm
Medicine Hat, AB
Maybe a guy could go to a semi truck wrecker and get the starter cables from one of those...plenty big enough, plenty long enough and dirt cheap I bet...
kc0stp
30 Hour Famine
Colorado
Factory battery mounts and size or relocated? Factory 2/0 should do it so long as you dont have hard starts to often, relocated at least 3/0 if not 4/0
MIDNIGHT RIDER
Overkill is always good; but, 1/0 cable, factory location or way back under the bed somewhere, is plenty sufficient to crank one of these little bitty engines in the coldest of times.
Most multi-batteried big-trucks will have either 2/0 or 3/0 and their engines are huge in comparison.
The starter cables on big 16- and 20-cylinder locomotive prime-movers are usually either 3/0 or 4/0; I once worked as a locomotive attendant and have started many of these engines.
I have 2/0 on my truck with remote-mounted batteries and it is way more than necessary.
More important than bigger-than-necessary cable is clean secure connections everywhere, both HOT and GROUND.
I see way more terminals burnt off than I ever see cables melted.
Considering all that, there is no harm in using bigger cable.
Gerhard
