popping through exhaust
8lugchug
N.C.
7.3 idi non turbo zf5 trans .Need some help ... having a loud popping sound through the exhaust. Anybody with same experience? Valves ?
Where to begin
DaveBen
Ukiah, Ca
When do you hear the popping? At start up or after it is hot?
8lugchug
N.C.
Seems to be after it warms up it gets louder
Kinda just sounds like it’s running rough when you first start it
But popping def gets louder after driving a little
8lugchug
N.C.
Update .. I pulled the valve covers and checked the valves/rockers etc
Found one valve that had some play in it
Seems to me like the spring is either broke or wore out def not seating completely
Also found a lot of wear on the rockers(valve side )
Is there anyway to flush these engines
I had quiet a bit of build up in it
You can flush these engines out, but I can't remember what others have used right now. What kind of build up? If it's sludge, then that's "normal". If it looks like charcoal, then that's a sign of bad valve guides.
lewisstevey7
