options for tach signal
im still trying to find aftermarket gauges for my 87 F350
with the oddball hall effect IH used, what are some of my other options for getting a tach signal?
heres a short read about alternator signals, does not seem to be the way to go.
http://www.amplepower.com/primer/tach/index.html
anyone have any other opinions/options?
DaveBen
Ukiah, Ca
I agree. First , the pulley ratio of the alternator and the pulley ratio of the engine would have to be found. And them you would have to figure out the numbers of poles in the alternator, and do the math of how many turns of the alternator equals who many turns of the alternator multipied by the number of poles. And finally build/buy a sensor circuit for the alternator. Does not sound easy. Why not just make a sensor holder and go off the crank?
Dave
i am now LOL he wants to use the stock stuff, which is the hall effect. correct?
You could do something like what I did, do it better, but you could use this general concept.
https://www.youtube.com/watch?v=FKOKz2zUcAc
from my research ive been doing this morning,
there are 3 types of sensors, hall effect, proximity, and alternator.
ive been reading a proximity sensor is programmed for the number of teef in 360*
if i delete my vacuum pump, i should have all the room in the world to install the prox sensor.
now if i can get SW to provide the sensor, is another story completely LOL
laserjock
Almost there...
I think the proximity sensor will be a hall sensor too. Most of them are.
typ4
Newberg,OR
If you get the right tach the stock sensor will work. Some version of this is used on semi trucks. I just put a vdo speedo in our 85 IH dump truck. Calc pulses, tire size gear ratio so on , program speedo with button on front and instructions, good to go. They make a tach also.
typ4
Newberg,OR
IMO, digital gauges are very annoying, distracting, on long trips
