Opinions/experiences with the "typefour" ZF mod
jaluhn83
Upper Marlboro, MD
Couple thoughts:
1) Why do you want a wide ratio? The close ratio trans matched the diesel power band pretty well with stock gears. Even with the close range I don't like the gap between several of the gears. (partially because of the quirky way my turbo system works) All a wide range is really going to get you is a deeper 1st which you really shouldn't need with a 4.10 and stock tires. If you do need super low range just put the t-case in low.....
2) There's no such thing as an over/under GV or US Gear unit. It's either over/direct or under/direct. You could get them setup either way, but it's not a overdrive/underdrive in one box. The brownie box is the only aux trans that can give you a true over/direct/under.
3) The GV unit is really not designed for splitting gears. It's designed to add an extra top gear. You probably *can* split with it as long as you're going fast enough (over 30-40 mph) but that's really not what it's supposed to be used for. Remember that the more you shift it and the more load it's under the more you'll wear the clutches.....
When I choose too I use my gv in all the forward gears. Just around 20 or 25 mph these units make enough hydraulic pressure to shift fine. I start in 1st. Then run it up to 25 mph and shift in the gv. Then run that till I can shift into 2nd and at the same time out of the gv. So now I'm in 2nd. Then shift in the gv. I do this all the way till I have the rpm and road speed I feel is the best for what I'm hauling. I can get 8 forward gears. I can't underdrive 1st. I have to be running before I build pressure. With 3.55 gears its sometimes a tuff pull from a dead stop. Thats why I want a set of 3.73 or 4.10 gears out back.. RLDSL has 15 forward gears with his brownie trans behind the ZF5 speed and 3 reverse gears.. Thats the best choice of gears anyone could want..:thumbsup:
