ghunt
I'm looking for a little input on this problem.
Last summer, I took my truck in to have it inspected. In the driver's side rear drum, the bottom spring that connects to both shoes was broken (looked like it rusted in one spot and broke) so I had to replace it.
While I was in there I did the shoes, and all new hardware. I disassembled the self adjusters on both sides, put a little antisieze in them for lubricant, and tried to make sure everything else was cleaned up and/or lubed as needed.
Well, ever since I did that, the driver's side rear brake has been dragging almost all the time. Worse if I use the parking brake, although not always.
Two weeks ago I took the drums off and backed off the adjusters on both sides. The driver's side was noticeably adjusted wrong as I had to physically pull the drum off since it was catching on the shoes. They have since adjusted back out and the driver's side has adjusted itself too much and is dragging again.
What do I need to look for that would be doing this?
