johneich
John, 1983 F250
I am cleaning mine in kerosene then brake cleaner then blowing it out with compressed air, so my question is which way would I blow it out if I wanted to be blowing in the reverse direction of the fuel flow?
All filters, no matter what kind of media, the flow is from the outside to inside.
Not technically true. You don't see a lot of them (especially in automotive applications), but inside-out flow filters do exist. Assuming the filter design uses a core, these style filters are easy to spot becuase the core is on the OUTSIDE of the media, not the inside.
Mike
Thanks for the insight Mike, I assume this type of filter would not have a round shape? More oval maybe? or one end smaller and the other end of the oblong shape larger? Just a life-time learning kind of question. I suppose it could be round? Then one would have to identify it only by looking at it while it was not attached to a vehicle? (Media to one side and pipe plug to the other? Or it might have a clear bowl like the Carrier?) Are the filters you speak of common in tractor, log splitter or other small hydraulics?
