Old Banks W/CDR
65sixbanger
New Braunfels, Texas
Old Banks W/CDR and RDT??
Ok I have the Banks Non Wastegated Turbo with the CDR still hooked up to the front of the ip cover. Right now oil leaks around the intake and makes a complete mess after a few hundred miles. I have tried to make a RDT, but last time I did that oil was everywhere when I opened the hood?? Could this have been because I left the CDR bolted on? I really wan to get rid of this leak around the intake. Thanks
Lance
85hauler
Reno
I'm running a RDT with a nonwastegated banks on my '88. I still have the CDR bolted on but not connected. If you end up with oil everywhere when using a RDT then you probably have something causing too much pressure in the crankcase.
There are a number of things that will cause too much pressure. If the RDT is not routed so that the air passing under the truck creates a slight vacuum on the end of the hose. Or if the air passing under the truck is being forced up the hose. Too small of a diameter hose being used for the RDT. There are alot of possible causes.
Bo17
