oil leak: rock auto rant
steelheadguy
Registered Idiot
Southern Oregon
Well. Usually I go to the local parts store to get what I need for an oil change. Fl-1995. This time I was lazy and ordered 2 filters from rockauto while I was ordering other parts. I even made an impulse buy and ordered a fancy drain plug that doesnt have to be removed to drain the oil. Dorman EZDrain.
Now I have leaks from both the filter and the drain. Loosening or tightening does nothing. Was I to add my own gasket to the drain plug? The motorcraft filters are fl784. I put oil on the ring before installing. Any tricks anyone can think of before I drain the oil and start over?
Most things made by Dorman aren't worth a crap.
Now fumoto OTOH.....
So is it leaking from the valve or the seal? I would say you likely need a seal there.
I would snug the filter a bit.
There needs to be a copper crush washer on that drain, the gasket on the filter may have been shoved to the side or came out if it’s grove as well
austin92
Brazil. IN
Check to make sure the gasket from the previous filter wasn’t still on the block when you screwed the new filter on. Double gaskets won’t seal
Cubey
Van dweller
Fl1995s work fine on my 87 6.9. Never any leaks. Copper washer for the factory drain plug. (I should get magnetic before my next oil change)
Macrobb
North Idaho
My drain plug has a plastic washer on it - those work just fine as well.
edit:
Just to make sure you guys know... The same plastic washer was on it when I bought the truck. It wasn't new then, and it's been 3-4 oil changes since?
Also same with my '88 - had the same plastic seal for like 4 years until it got /really/ flat and I happened to have a better one handy... I don't think I've ever bought an oil drain plug seal.
ps444mike
Southern Calif
I use to get a copper washer with a rubber insert from autozone.. never had a problem used on one side then flip an then a new gasket
Cubey
Van dweller
The hard nylon washers are probably ok if replaced often.
Do NOT use those usually blue bendy washers!
I use solid copper washers, no rubber. Torqued to spec with a cheap HFT torque wrench. They don’t really crush much if tortured properly and can probably be reused at couple times.
(I have rebuilt two front ends, Dodge B300 & F250, with those torque wrenches, they seem reliable)
Macrobb
North Idaho
Wait... People actually torque their drain plugs? I always just use a crescent wrench(or actual wrench if I happen to have it handy) and just torque to "snug" and call it good. No issues in the last 5 years, so...
austin92
Brazil. IN
I’m with you, been changing oil since before I had my Licence and never torqued a drain plug. Never had one leak and never had one strip lol
Cubey
Van dweller
It doesn’t hurt to torque. I’m not in any hurry when I’m changing the oil. It’s not like I’m in an oil change job where every minute counts.
tke395
