Oil in exhaust
Minuteman96
Sierra Nevada
This doesn’t look right to me but I’m still fairly new to these engines. I know they usually seep oil but obviously there’s quite a bit. Should I be concerned? I haven’t noticed any smoke at all from the exhaust and I always keep a close eye on it because this is my daily driver.
NeverHave-I-Ether
Texas
Check your valve covers and CDR valve on the back of engine behind the air intake. They are notorious for leaking. My truck leaks the same way right into my exhaust pipes and I pinned it to the valve covers. For me passenger side rear. On my photos you can see how dirty and caked they were, then see the leak after it's cleaned off.
Few winters back the Water Pump started leaking, and being the woosy I am and not wanting to work in the cold, had a shop do the work.
They mentioned about the leaky VCs so yeah go ahead and do them too.
later on they started to leak. I thought why not remove ea bolt, blow out the holes with Carb Cleaner, clean off the threads, and use Lock Tight. Worked like a charm.
For the most part it is pretty dry, did have to tighten a couple bolts though.
