skeeter72
First off, i would like to thank you guys for making this an awesome forum. I have learned more in the past couple months looking through yals tech articles and threads than i have in a year of looking on other forums. Anyways, I have a 94 f250 7.3 e40d currently with ~146,000 miles and have had it about a year and half. Since owning it i have replaced the oil cooler and the glow plugs on it, everything has been running fine and sounding fine until today. The oil pressure gauge (stock) has normally been hanging around the "O" and the "R". Then all off a sudden it is starting to twitch and progressively get lower, i checked the oil and it was low, so i put more in, but it is still twitching and hanging around the low to really low mark. It is also moving a lot. I also notice when i accelerate ( i do not accelerate fast maybe up to 1500rpm) the needle will go all the way left and then start twitching its way back to "normal" spot (normal as in how its been acting in the past 5 hours). Is this a sign of problem in the engine or is the gauge is going. Thank You in advance. Cheers.
On a completely different note can any of the Kentucky guys on here recommend where i can find test strips in the lex area.
