oil for turbo
86F2506.9
6.9 International
Myerstown, PA
ok where is the best place to run my oil feed line on the block if you can pictures plz
Depends on what turbo you are running. The recommended location for the Banks turbo is just back from the oil filter on the bell housing flange web. Don't try to use any of the plugs in the rear oil cooler header. All those are unfiltered oil.
RLDSL
Diesel fuel abuser
Arkansas
Make sure to clean out the hole before you thread a fitting in so you don't feed your turbo a belly full of carbon plug.
RLDSL
Diesel fuel abuser
Arkansas
its the ats non wastegated
On mine I just put in a T fitting for the oil pressure sender at the back of the block with a leg for a -6 AN hose attachment and ran an aeroquip hose up to the turbo. The 088 is threaded so I just got an adapter for that end as well.
crispy74
