Depends on what turbo you are running. The recommended location for the Banks turbo is just back from the oil filter on the bell housing flange web. Don't try to use any of the plugs in the rear oil cooler header. All those are unfiltered oil.
On mine I just put in a T fitting for the oil pressure sender at the back of the block with a leg for a -6 AN hose attachment and ran an aeroquip hose up to the turbo. The 088 is threaded so I just got an adapter for that end as well.
