direwulf23
So, I got the oil cooler out of 95 F250 PSD and replaced the o rings and the front/ back header gaskets. Everything is sealed except the rear header at the bottom.
Is there any way to seal this without taking the oil cooler back out of the truck? If not is the gasket still likely to be good or does it need to be replaced altogether? (which I don't think you could just get the rear header gasket by itself).
