Oil Cooler O-rings
I'm just checking in on this item. As I recall its install ALL the o-rings on the bundle and not the small ones in the headers. I hopr thats what it is. The use of plenty-o-vasoline is the reccommended lube. Thanks guys.... :angel:
geonc
SPIDER BAIT
NECKVILLE North Carolina
YUP! all o rings on the bundle ;Sweet
Sum fine emory cloth on the inside of the headers and the bundle necks won't hurt either :D
Personally I perfer using plumbers grease opposed to vaseline........
Be as liberal as you want :D
Big box stores has it.
Back in the 80's, Detroit Diesel issued a TSB directing NOT to use vaseline to lube the liner seal rings on the 53/92/149 series due to the temps crystalizing the vaseline and causing failures. ie: coolant in the oil / out the air box drains and alot of the AB drains were check valved back to the pan :eek:
Now I realise the7.3 oil cooler bundle is not subjected to the extreme cyl temps
found on those engines-- 1k deg+ {this is actual cyl temps--NOT stack temps} but I have allways had success with plumbers grease so ;Sweet
Just my couple pennies.......
Cleveland, OH
when i did mine i replaced all 4 o-rings. i got them at the dealer and used vaseline.
To press the bundle back together i used a hydrualic car lift (with the bundle between the lift and ground and it has worked fine.
matt
