You might try this, when oil is hot loosen filter 1/2 turn, then poke hole
good thought---also--always use filter wrench--at the BASE of the filter--not the other end--very seldom will you tear the metal case out of the base---
Matthias went down that road in Bowling Green. He had to change an oil filter on his truck that HE put on. I told him at the time, my rule for changing filters. You put it on as tight as you can get it with ONE hand. Unfortunately, he didn't think that was tight enough, and he used both hands. He now understands that oil filters generally stay on really good with very little torque, and follows my rule.
interesting..... both the 90 and 99 have to have the filter turned tight with a filter wrench, or else they leak.
I always go with the rule that once you get it fairly tight with one hand, go 1/2 a turn more and leave it...which is pretty much the same thing you said Mel. I have NEVER had a filter stick...well, one that I put on anyways.
I have found that draining the filter if it's stuck helps out.....clean it off with brake clean, and fold a piece of sandpaper in hald, so the gritty side is on both sides.....stiuck that between the filter and band of the wrench for added bite to minimize slippage.....I learned that working on the BIG trucks when I was 19.
