How are the original factory freeze plugs installed? Do they use any type of sealer or what? On my original 89 block the stainless steel plugs have a very differant dent in them as compared to the factory set I had installed in my rebuilt block. If some of you remember I watched them install these and hydro tested the block to 35 lbs without any signs of a leak. Well I now have 3 plugs that started weaping but ever so slightly. One was behind the flexplate and the other two are behind the oil cooler. I never see any coolant on the ground. Just some stains on the block and sometimes you can feel some wetness. This is not a happy thing either. I probably will be pulling the motor and installing the spare set of the factory plugs but information is needed first. I may just remove a plug from my original motor and see what it looks like for sealant.....
