If it's an OBD1 scanner on an OBS truck the only thing it will check is the transmission, the E4OD. Would the scanner show any reaction if the truck had a manual transmission? Am I right on that?
I'm not sure that there's a port for the OBD on a manual transmisson truck. I don't remember that part. All I ever used the OBD port for was to set the FIPL correctly (at least in range).
