Obd not powering scanner
Gachris
Georgia
Trying to retrieve codes but the obd port I hooked the scanner up to isn't communicating at all . Fuse to check ?
The IDIs with a E4OD have the Ford OBD1 plug under the hood close to the master cylinder. On vans, I have no idea where it's at.
gandalf
Senior Member
CA &/or Maine
If it's an OBD1 scanner on an OBS truck the only thing it will check is the transmission, the E4OD. Would the scanner show any reaction if the truck had a manual transmission? Am I right on that?
We need to know more about the truck.
I'm not sure that there's a port for the OBD on a manual transmisson truck. I don't remember that part. All I ever used the OBD port for was to set the FIPL correctly (at least in range).
