My truck has the original Ford R12 AC compressor and was converted to 134 approximately 5 to 7 years ago. It worked "OK" but never really got cold. The system was opened last year when I completely disassembled the truck however I did take care and protect it from dirt prior to reassembly. Now with summer really turning up the heat, I decided to recharge the system and started by replacing two of the three hoses as well as a new orifice tube. Now I'm not an AC guy, however our son does work in the commercial HVAC world with access to all of the proper tools. Neither of us are familiar with auto ac systems. He understands how they work but unfamiliar with how much refrigerant and oil should be used... We removed both of the old hoses (one on the high side and one on the low side) and covered the hose connection points with a clean rag then purged the system with nitrogen which produced a gurgling noise and sporadic spitting of oil into the rags. He then connected his vacuum pump and this ran for approximately two hours. Again this started with a mist of stinky oil from the vac exhaust which cleared within the first half hour. Then after running for the two hours and holding vacuum to confirm no leaks, he used the vacuum in the system to pull 19oz of r134. Then I started the engine and the compressor would cycle on and off. He added a 7 oz can of PAG oil and compressor continued cycling on and off. Next we added a 12oz can of r134 and compressor ran constant with low side gauge reading 30psi but air temp coming out of vents was 65 degrees. Tried adding another 12oz can of r134 however system would not take it. We're guessing we added too much oil or the compressor is shot? Need help please!
