homelessduck
take a punch and hammer a indention between the pump and housing, now take the inspection cover off the front of the motor (the little one with two bolts) you should see 3 bolts and a dowl pin, the bolts are 8mm or 5/16 12pt socket, take them out, then take the three 9/16th nuts holding the pump, push back twist fight it a little and it will come out, DONT REMOVE THE GEAR COVER! and you wont loose your timing, then putting the pump back on is a reverse procedeure, and line the puch marks back up and its timed to were you took off from
I guess it actually doesn't really matter if I lose my timing if I get the bottom end from Blackdog/Cetane. I will have to assemble that block and time it anyway. Ugh, more work..
