Welcome to the forum, first thing to check is the connection at your tach sensor, it is located to the right of your oil fill in the pump gear cover. The wires coming out of the sensor go bare over time, and the plug can get dirty. You can also pull the sensor out and clean it to see if that helps.
Where in Texas are you located?
